mr.ser i know you are a bad man
just kiddin mate...
there is absolutely nothing on the a/c amplifier board. im gona have to use the trusty old multimeter, some long stretch of wire, and a +12volt source and trace out which wire goes where, do some continuity tests etc etc...tedious work!
again played with the tps today
i downloaded some factory manual for 4afe/5afe/7afe and translated its russian to english (the tps part). it said something like:
so finally after adjustments, with throttle fully closed, vta measures 0.4 Kohms.
...and then I cleaned out all the grounds, added a 1 or 0awg (dunno which) ground from body to battery -ve
and you can name what you want for a treat
