it is also written to topup the reduced amount of oil and keep it at optimum level accordingly.
They had mentioned this to shoo off the clients with this issue . how many of the damaged vehicles would they repair .
How much does it consume!!?
Dear,Upon ur recommendation in this post i have switched to taglon 5-50 from zic 5-20, let's see how it performs now One more thing can you please tell what is exact amount of mobil oil needed to pour with filter change? 3.3 L or 3.7L (Vitz 2013 1.0)
I know someone who killed their engine by pouring 5w50.
It is super thick.
Rev the engine hard and good chance you'll destroy it.
Flows too slow. Not meant for 1kr.
dear its not thick. it covers a wide range of application. it acts at 5w at cold startup and accordingly.
i think as per manual its 3.3L. u can check the exact quantity written in the car manual.
keep a check at car's oil level hopefully it will be fine IN SHA ALLAH.
3.1 litre
What compression value does a healthy 2szfe have?
170+
I did dry test and it came out 130 to135 across all cylinders. There is no smoke. It's consuming engine oil. I recently bought the car, the previous owner poured PSO 5w30 fully synthetic. Mileage is 95000 km. Next oil is due.The car has driven 7650 km with current engine oil. So we can say that it consumed 2 liters of engine oil against 7650 km.
Then suggestion did u got, as similar problem in my car vitz 2013 model
Perform the smoke test first then confirm is the engine of your car is healthy or consuming any engine oil
I have same problem with my vitz 2011 reg 2015. Plus tick tick sound on steep way
