Aoa, need some advice, i have a yaris cvt 1.3. I recently had a bit of a mishap where a rock on a village road hit the bottom of the cvt pan and cracked it. I immediately shut off the car and towed it to a nearby workshop (dealership is not available in my area and it was a bit of an emergency as I stranded while travelling home with family). Pan was welded and leak tested. Got toyota genuine cvt fe 4L tin from market. Since I didn't know how much fluid had leaked so didn't know the quantity to fill back in but had an idea that around 3.8-4L goes in if you takeoff the pan, so poured around 3.8. Also, mechanic did not have a lift so couldn't check level. Car drives ok with no shifting issues. Should I still take it to the dealer to check the level? Also I've driven around 400km, so should I be worried about damaging my cvt by over/underfillng since it drives fine?
Your kind feedback would be quite helpful
