Yes. Why 2 pipes are blocked?
I donât know.Thereâs another T installed aswell.I guess someone has fiddled with it.
Remove the extra one.
Do I have to change all the fuel lines to connect the single one?Or they will remain the same?
No you just need to sort them out, and if you can then post some more pictures.
Hassan bhai I have no idea how to sort them out.I am mind boggled as three inlets to the proportional valve arenât at all connected.I guess the 4th one goes to my front passenger calliper.
This is how pipes should be connected. Change the valve as it would be choked with dust. (Ignore the length of pipes)
Any sprinter 2 door, trueno or levin is up for sale ? Or even maybe abandoned somewhere! Please Lemme know!!!
Best of luck in thatâ
ye bhi theek hai
Assalam u Alaikum Hassan bhai. Hassan bhai need your input on somethings about 84 corolla.
@sksobaid Wailaikum AssalamGii?
Masha Allah thatâs a clean car.
As you live in lahore, i have been following you guys, you, SerGTR, Xulfiqar bhai for a long time now. You know where can i find good BT/ST for my 84 corolla? and is it bolt on on ee80 chassis?
hard to get ST and BT now. you might find 16v in bilal gunj. for ee chassis timing side mount need some work, other then that it's almost bolt on.
Not even in Peshawar? For 16 value whatâs price for 7afe if you have any idea. I would try and find ST/BT first and 7afe would be my second option. Do tell if you come across any. JazakAllah
You might found it in Peshawar. Price of St and BT will going to be same as 7afe. Whereas 4age 16v used to be cheap like for 60-65k.Sure.
One guys from karachi is sellin his BT complete engine. His demand is 120k. Is it reasonable?
