1) what is the difference between aerox 5.2kw vs infini solar system. Aerox 5.2kw is hybrid and can combine utility with pv. It can also runs without battery?
If you can afford infini, its a better choice.
2) how much power do you get on average per day in summer and winter through PV from 5000 watt system? I just want to know the actual power from rated power after losses.
My PV array is 4,240 watts total. Power I get: Winter: 2,700 peak noon, average load less than 2,000 watts. Summer: 3,700 watts peak noon, average load less than 3,000 watts.
3) what is the peak duration of maximum solar power in summer?
Pulled this PV power input data from June 26 2019. I am not netmetering, so this is dependent on house load.
4) what do you recommend mono or poly PV for hot climate in Faisalabad.
Poly for hot climate, Mono for cold or mostly cloudy climate.
5) i want to install net metering as well please guide me about the approval charges etc.
Don't know, I am not net metering.
