Oh clutch pressure worn out means it will remain sluggish and coming from cuore to liana, liana would feel like a sports car.
Secondly there's a catch in this story, fuel pressure can't be adjusted manually. The term adjusted the fuel pressure is bogus. He must have done some magic trick with your fueling. However liana has a return system fuel rail and it has standard pressure of 40-45psi which can't be adjusted. Fuel pressure adjustment is only possible in after market adjustable fuel pressure regulator only.
So it shows there's a problem with engines compression bringing down the economy because a good liana 1.3 pulls around 12-13 local and 15/16 long.
I am Islamabad based g13, you can search my contact on Google. The name under my badge.
