That’s great! So is the cruise control and MID display buttons both correctly? Can you please share cruise control activation snapshot?
I did some research regarding the climate control as well. Here’s the part number (97250-f3da0 QAKB2) that you need;
Climate control requires sensors for accurate working not just the panel
Yes, you’re right. Might need to install the sensors too; in most cars there are two sensors. One for inside temp and one for outside temp. Also, it gets mote complicated when you’re installing dual zone climate control because then there is different blower motors and ducts for each zone.
The GL model cooling box/blower is same as GLS model. Outside temperature sensor is already installed as you see outside temperature in cluster but for inside temperate 2nd temperature sensor inside climate control.Thanks for your assistance but I already have Hyundai Pakistan BOQs and parts number for Elantra & Tucson. Part is already ordered and will be available with me after eid. I will post results once i done.
Best of luck, really liking what your doing. Will definitely help people decide between Altis 1.6 at and Elantra
Which dealership in Lahore is the most recommended one for PMs & after sales service?
I'm also looking for this can you share aliexpress link of product .
Hyundai Premium
Anyone has access to service manual for Hyundai Elantra
The China made is not good fit for your car. Go for original one from Hyundai Pakistan or buy from Amazon USA.
Kindly confirm whether routine spare parts (oil/ air/ ac filters, spark plugs, lights etc) are readily available for elantra or whether there is an issue regarding this
all routine parts are available without any issue.
For all Hyundai owners, which dealership in Lahore has the best aftersales service?
Hyundai Premium, Multan Road
AoA, Has anyone tried installing TPMS (Tire Pressure Monitoring system), If we install sensors will they work?
Rizwan bhai kinldy give me your cell number. Need to know about installation of cruise in elantra 1.6. Kinldy give me your number or text me on 03497869255
Hello
Planning to buy a car...was looking at Altis 1.6 CVT-i & Elantra GLS
How is the car compared to corolla &Is there a chance to get the Android Auto & Apple Car play Unit instead of the current android unit installed in it
Thankyou
i have kept Altis 1.6 and upgraded to Elantra GLS AL HAMD U LILLAH.
Elantra is mile ahead in every aspect and a much much better and accomplished car.
Go for Elantra. you wont regret the decision IN SHA ALLAH.
