New anti slip steering cover imported from china. Alhamdulillah
Has anyone used them? I have got them to give it a try. I hope it will do good cleaning of Car AC vents and evaporator
Do tell if they worked...the flamingo prodcits I have used weren't great
Ok sure will give the review after using it
this product is bad. my friend used it in his wagon r. it remains good for few days then it started smelling bad .
Ohkk noted. I haven't tried it yet. Let me check also
flamingo products are not good as they advertise, once i used its spray polish just like 7cf. it was not good
Although I have used it's dash polish which is really good. But let's c how it's AC cleaner works
i guess it can clean the ducts good, but for blower i would suggest to take it out and clean it manually.
I have cleaned the blower of my Honda city also myself in the past by taking it out. Actually this AC cleaner is meant for cleaning evaporator behind the blower, I hope it will clean that
The AC Pro cleaner has given me good results. Also sprayed it down the glovebox inside the blower/evaporator, the cooling of AC has extremely improved and there is also no bad odor/smell. Alhamdulillah
Thanks for the update
Hey guys. Alhamdulillah changed end to life led head light bulbs of my santro to new halogen bulb which I also had imported from china. Will further see the result at night and adjust the bean accordingly
Alhamdulillah the result of new bulbs after beam adjustment
Diy repair of santro's broken front door handle. Dismantling of handle hinge rod and repaired/joined broken plastic part with help of my adhesive glue which I had imported from china myself and give it a little heat for quickest hardening. Alhamdulillah handle is now working like charm in my santro door
nice
park it opposite straight wall and then see the flame of light.
