There were a couple of things I had to take care of...
1 - GPS antenna is different from a normal standard.
2 - Camera is 6V instead of 12V like the rest of cars.
3 - Camera harness is not RCA based and needs different solution.
4 - Unlike other headunits, you need to have a trigger signal from reverse to view reverse camera signal.
5 - GPS will update your location but turn by turn navigation and re-routing works only if the speed sensor signal wire is connected.
There are other things I need to sort out too, like AUX cable, MIC and take info from ECU for maintenance menu. Once done, I'll be updating this thread.
I don't know if any of you will need this info but I'm going to gather all info regarding installation here anyway.
