Related to above mentioned post:
I am planning to change my tires to wider one for more grip as I have continuous drive of high speed.
So I am thinking to switch to 195/65 R14 or maybe 195/60 R14
@hash4u I read your post somewhere that you have used these tires on your civic
Does these wider tires hit the inner walls or fenders in any scenario?
Also my current size is 185/70 R14 which is almost 0.7 inches higher than the stock size (185/65 R14). Its hitting when at speed above 60 and there is uneven road, only the rear tires hit inside the well (sharing pictures)
Will changing the size to 195/65 R14 which is 0.2 inch lower than the current size (185/70 R14) will lower these incidents?
@Xulfiqar @rajaatta
