Does anyone know the difference between AGS battery series? Like there is SP 38AH battery but also GR/GL with same plate and AH, so which one is good. Someone told me SP is good for ups not cars.
There are different nomenclature used for specific application of a battery. Yes automotive designed battery is not recommended to be used for ups back ups & vice versa. Automotive batteries provide quick burst of currents to starter motor to provide required torque for starting engine, but they are not good to provide longer power outage backups for ups.
GR , GL indicates left & right terminal configuration of battery, like thick pole on left or right etc etc
Hey guys, Inshallah gonna buy AGS batteries for a mosque's UPS again in few days. Alhamdulillah have gained access to higher management of AGS batteries manufacturer. Inshallah will have peace of mind for performance & warranty periods without any hassle.
That's why saada Khushboo batteries fail early in Pakistan. If prepared with proper spec pure sulphuric acid and 0 TDS distilled water then saada Khushboo batteries last longer till unimaginable durations. I bought 02 AGS batteries from main AGS distributor. The irony is that despite my nearly fighting attitude with distributor to use prep electrolyte with distilled water and pure acid which he refused and I had no choice then to buy batteries prepared with trash water electrolyte
Is mein AGS ka koi qasoor nahi, AGS is a renowned company, we as a nation are morally , ethically and technically corrupt.
I also got tds meter of my own to test trash water quality of AGS distributor, it's tds was 200 ppm
Why not supply the shop with distilled water and CP product acid yourself?
I have stock of 4-5 ppm Osaka distilled water at home, I even asked distributor to make electrolyte from distilled water bottles present at his shop for which I will pay extra but he refused arguing that we don't do it and sulphuric acid and water mixing is as exothermic reaction which takes a day for the electrolyte to cool down, it is exothermic but his logic of cooling down of electrolyte in full day was ridiculous and danger of electrolyte to the boiling and splashing in the air etc etc , he said he makes all batteries electrolyte with khaalis tap ( trash) water
Secondly, I didn't have stock of cp sulphuric acid at that time otherwise I would have prep electrolyte myself, my father left running cp sulphuric acid plant a 2 decades ago and we used to have cp sulphuric acid at home always for toilet cleaning also, so even now I am curious to buy cp sulphuric acid from somewhere again, Even I looked up for ready electrolyte pyro bottle online but could not find.
I highly doubt he said it
"Humari garunty nahi ho gi phir"
. Hum 5 Saal se aisay hi trash water use kertay Hain
He exactly not said but meant to say it, he said heat nikalti hai bohat
The reaction is exothermic and will cause boilover, but you can use chilled water to help. And it takes abt 2 hours to cooldown at max in winters
Your shop refused because it would expose their cheating ways.
True. It doesn't take long to cool down mixture of cp sulphuric acid and distilled water, yeah it can cause boilover but that can be avoided by using chilled water.
Every second battery shop is using trash water electrolyte which is dilemma
Procedure on how to make battery electrolyte for saada Khushboo batteries.
Alhamdulillah my car's phoenix saada Khushboo battery has completed it's 2 years hassle free service life. Alhamdulillah still going strong.
Thats childs play
A proper CP product prepped battery I used to activate lasted 5 at minimum and longest I saw one in service was 9 years before customer sold his car (2.0D corolla)
