do you have a 4 wire TPS?
the 4th wire connects to the pin called IDL - which means "idle switch" - btw code 41 is not just TPS code, it also will set if you dont have the STA wire connected.
I dont recall seeing a 4 pin TPS on a black top 4AGE (its been a while though) - you sure the wiring is original to the engine?
